Preprocessing
Preprocessing
Parameterising an angle for a 2D Surface, Spaceclaim
    • Eoin
      Hi all,
      I am trying to create parameters so that I can change the angle and move a segment of asketch laterally, as highlighted in the first image (changed laterally from 12 mm to 10mm and the angle from 15°-11°). While the shape is a sketch I can change the dimensions, but once I convert it to a surface I am unable to alter the angle, what should I do to convert the dimensions to parameters?
    • Eoin
      Thank you very much for answering so quickly. It is very much appreciated!
  • The topic ‘Parameterising an angle for a 2D Surface, Spaceclaim’ is closed to new replies.
