November 25, 2021 at 6:54 am
Ankusham
SubscriberOnce i solved my analysis, More than one result file, log file and some other except .db and .dbb generated and saved.
file name for duplicate files is differ by only ------0.rst, ------1.rst like this. Please find the image attached for better understanding. It increased my simulation folder as well as simulation time. Please help me out.
November 25, 2021 at 3:51 pmNovember 26, 2021 at 1:19 pmGovindan Nagappan
Ansys EmployeeAre you using distributed solver with 2 CPU's? This will result in two split result files. Example file0.rst, file1.rst (split result file for each CPU)
You can turn off distributed solution and solve the model again
remove the -dis from the command line (4.1. Starting a Mechanical APDL Session from the Command Level (ansys.com))
November 27, 2021 at 5:13 amNovember 27, 2021 at 5:37 amNovember 27, 2021 at 6:15 amAnkusham
SubscriberThanks my problem is resolved by changing the setting from distributed to shared memory parallel.
Viewing 5 reply threads- The topic ‘Duplicate files generated by Ansys APDL 19.’ is closed to new replies.
3712
1313
1163
1090
1014
