Photonics
Photonics
Using Script to Extract Loss and TE fraction from Mode List after Calculating Modes
    • mwhitby
      I did FDE analysis for my simulation. Then I calculated the modes and got a data table inside the Eigensolver Analysis Tab called Mode List. From this data I would like to extract the loss and the TE polarization fraction. Ideally I would like to be able to extract these values and assign them to variable names, however it would also work if I can export the full data table to a .csv file. Is there any way to do this in the script?
      Currently in the script I have:
      run;
      findmodes;
      What I would like to do right after this is have something like:
      mode1_TE_frac = put command here to extract the TE polarization fraction for mode 1
      Is this possible? I tried using the getdata(); command but it didn't work out.
    • Guilin Sun
  • The topic ‘Using Script to Extract Loss and TE fraction from Mode List after Calculating Modes’ is closed to new replies.
