October 30, 2021 at 5:10 pm
vamsijc7
SubscriberI am not able to find the right options to change the smoothing length constant as a beginner. Do help me out.
November 1, 2021 at 11:16 amNovember 2, 2021 at 7:19 amvamsijc7
SubscriberHow to insert a Section object from the LSDYNA Pre tab ?
Can you please elucidate with some pictures or sentences ?
Thanks.
November 2, 2021 at 8:16 amAkshay Maniyar
Ansys EmployeeNovember 6, 2021 at 7:38 amNovember 10, 2021 at 3:27 pmAkshay Maniyar
You can use it with Ansys Autodyne solver. Transfer the model to Autodyne system(as shown in image)
Now, under Parts>SPH part>solver setting>solution you can get the options for smoothing length.
I have also attached the Ansys help link for your help.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/wb_adyn/adyn_parts_solvstruc3dsph.html%23adyn_parts_solvstruc3dsph
Regards amaniyar
Viewing 5 reply threads- The topic ‘How do I change the smoothing length of SPH Meshing in Ansys work bench ?’ is closed to new replies.
