TAGGED: grating-coupler, import, import-source, Lumerical-EME, Lumerical-FDTD
October 27, 2021 at 9:24 am
bernhard1
SubscriberHello everyone,
I am designing grating couplers. For this purpose I want to split the simulation into a short/small FDTD simulation containing the grating and a larger simulation using EME where I want to refocus the light using a long taper.
I managed to export the fields from the FDTD simulation with a frequency and power monitor and I also managed to import them to a port of the EME simulation. But when I do the EME simulation there is no light detected at the other port. I am using 100 modes for the cell groups.
Do you think I have to increase the number of modes or is importing fields from FDTD to EME not supported? Or do you know what the problem could be here?
October 27, 2021 at 6:04 pmGuilin Sun
Ansys EmployeeI am not sure how did you import for the data. But you will need to create a dataset with E/H and xyz. Please refer this exmaple:
https://support.lumerical.com/hc/en-us/articles/360034396394-Importing-arbitrary-source-fields-into-EME-ports
October 28, 2021 at 8:49 ambernhard1
SubscriberI didn't work beforehand but I found out that i can remove the frequency dimension with the "pinch" command and by that it works!
October 28, 2021 at 12:08 pmGuilin Sun
Ansys EmployeeYou are right that for EME source it does not need the frequency parameter since it is single frequency job.
October 28, 2021 at 12:18 pmbernhard1
SubscriberYes, I think that this should be stated somewhere on the support pages that you have to modify the data set accordingly for importing a source from FDTD to EME in comparison to FDTD->FDTD. Maybe you could forward this to someone who is maintaining these sites.
Thanks!
October 28, 2021 at 12:48 pmGuilin Sun
Ansys EmployeeOk, Thank you for your suggestion!
Viewing 5 reply threads- The topic ‘How to import FDTD fields to EME source’ is closed to new replies.
