Preprocessing
Preprocessing
In composite shell modelling which rosette option is suitable for semi elliptical shell?
    • venugopal4048
      Hello everyone,
      I want to model semi elliptical composite shell in ANSYS ACP. For that, I have to select rosette for ply orientation. There are several rosette types such as parallel, spherical, cylindrical, radial. Which one is suitable for modelling of semi elliptical composite shell?
      Thank you
      regards
      Venugopalb
    • Manish Dubey
      Depending on the application Cylindrical Rosette type can be used.
      Please refer ANSYS help documentation on the use case of Rosette type 2.1.5.2. Rosette Types (ansys.com)
      Thanks
      Manish
    • venugopal4048
      Thank you for your reply But, I am not able to open this link. What is the solution?
    • Manish Dubey
      Please visit ANSYS help documentation for more information on the use case of Rosette type https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/acp_ug/ch02s01s05s02.html
      Thanks
      Manish
  • The topic ‘In composite shell modelling which rosette option is suitable for semi elliptical shell?’ is closed to new replies.
