October 26, 2021 at 3:11 am
SV
SubscriberGreetings
How to calculate heat transfer coefficient inside a pipe with constant heat flux by Ansys, using post processing
Thank you
October 26, 2021 at 9:14 amRob
Forum ModeratorArea average? Plot contours? Make sure you read the https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/flu_ug/flu_ug_fvdefs.html definitions to understand which reference values are used.
October 27, 2021 at 3:11 amOctober 27, 2021 at 10:12 amRob
Forum Moderatorxy plots on lines will get the local values. For the cross section average you may need to create planes and report on those.
October 28, 2021 at 1:07 amOctober 28, 2021 at 11:04 amRob
Forum ModeratorYes, and as it's doable in Fluent there's no need to write any files out other than the standard ones.
Viewing 5 reply threads- The topic ‘heat transfer coefficient inside a pipe with constant heat flux’ is closed to new replies.
