Does anyone encounter this error in CFX? ‘ERROR #001100288 has occurred in subroutine CFXMSG.’
    • yu.zhu14
      Hello everyone,
      After running a simulation in CFX 19.2, the following error message appeared:
      Parallel run: Received message from slave
       Slave partition :    7
       Slave routine  : CFXMSG
       Master location : FINPAR
       Message label  : 001100288
       Message follows below - :
       | ERROR #001100288 has occurred in subroutine CFXMSG.        |
       | Message:
       | The following message handling error occurred:
       | Write
       | Hostname:  ce-yz17014
       | Port number:  56389
       | Messages will now be handled using a less robust method,  with a greater risk of parallel deadlocks.
       | Note: Ensure that the hostname shown above can be resolved from all hosts used for the run.
      This seems to have no influence on the results, however, when I tried to run another simulation using the results from this one as the initial condition, I encountered another error:
       Slave partition :    7
       Slave routine  : ErrAction
       Master location : Message Handler
       Message label  : 001100279
       | ERROR #001100279 has occurred in subroutine ErrAction.       |
       | Message:                              |
       | Stopped in routine FPX: C_FPX_HANDLER
      Any ideas on what happened here?
    • Surya Deb
      Is this happening for this specific model or can you replicate this with any CFX model?
      Regards SD
    • yu.zhu14
      Hi SD Thanks for your reply and sorry about my late replying.
      This error never shows again after I deleted a previous version of CFX V15.0 so I think it might be something related to compatibility.
      In regarding your question, it was happening for all models that I tried to run.
      Yours Yu
  • The topic ‘Does anyone encounter this error in CFX? ‘ERROR #001100288 has occurred in subroutine CFXMSG.’’ is closed to new replies.
