TAGGED: 2D, ansys-fluent, boundary-conditions, heat-transfer, udf-fluent
October 22, 2021 at 6:21 pmss_stardustSubscriber
I am solving fluid flow and heat transfer in a double pipe counter flow heat exchanger filled with porous media (see the domain in attached picture ). I need to apply a boundary condition to ensure continuity of energy and temperature at the wall-fluid-solid interface. The inner pipe wall thickness is required to be modelled as well. I am facing difficulty understanding how such a boundary condition( see attached picture) can be applied in Fluent.
Any suggestions regarding approach or UDF will be very helpful. Radiation can be neglected.
Thanks in advance.
October 25, 2021 at 2:29 pmKarthik RemellaAdministratorHello I've answered your question here. I'm closing this post.
heat flux at interface of porous media and wall in LTNE model ÔÇö Ansys Learning Forum
Karthik
Viewing 1 reply thread- The topic ‘Boundary conditions with LTNE in pipe filled with porous media’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Fluent fails with Intel MPI protocol on 2 nodes
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- UDF, Fluent: Access count of iterations for “Steady Statistics”
Top Contributors-
1406
599
591
555
366
