October 22, 2021 at 2:57 am
chenjian
SubscriberHi, everyone
I'm doing the harmonic analysis of langevin transducer, but the deformation results is not what i expected. The amplitude in the front surface of the transducer should be about 5um.
This is the result.
October 27, 2021 at 6:05 pmdlooman
Ansys EmployeeDid you specify damping? If the excitation is at resonance, damping is needed to limit the response.
October 28, 2021 at 4:52 amchenjian
SubscriberNo, how to set the damping?
Viewing 2 reply threads- The topic ‘Problems about the harmonic analysis of langevin transducer’ is closed to new replies.
6600
1311
