October 19, 2021 at 12:39 pm
i.tamunodienye2
SubscriberHi All,
The Ansys User guide stated that contact angle of 90 deg does not wet the wall. And also that at contact angle of 30 deg (air) and 150 deg (water) , the wall is not also wet.
Please i want to ask which suitable contact angle can wet wall surface and is this suitable for multiphase flow modelling where flow regimes are important output.
Your kind help is much appreciated.
27.2.11. Defining Multiphase Cell Zone and Boundary Conditions (ansys.com)
October 19, 2021 at 3:02 pmRob
Forum ModeratorCan you provide more details? The angle refers to capillary effects, so depending on scale and requirements you may not need to include contact.
October 19, 2021 at 3:38 pmi.tamunodienye2
SubscriberI am only modelling multiphase flow in a pipe and felt contact angle need to be turned on. I am only looking at a physical situation.
What is your thought in this insyance?
October 19, 2021 at 4:00 pmRob
Forum ModeratorHow big is the pipe, and what is the situation that you are trying to replicate?
October 19, 2021 at 4:33 pmi.tamunodienye2
SubscriberThe internal diameter is 0.21m about 8 inch. I will be try replicate various flow regimes: slug, churn, bubbly and annular.
Also forces acting on the bend are important.
October 20, 2021 at 10:30 amRob
Forum ModeratorYou want to resolve bubbly and annular flow with VOF? I assume you've read the theory guide to understand how that works and have sufficiently resolved the mesh?
October 20, 2021 at 1:43 pmi.tamunodienye2
SubscriberThe important flow regime is slug as it is the flow regime that can create dynamic load on structures due to its intermittent flow. The guideline suggests you select multiphase model based on the flow regime of interest. Ofcourse the flow regime changes as fluid makes a turn around bends. But the important flow regime is the slug and churn as well
October 20, 2021 at 3:13 pmRob
Forum ModeratorHave a look at multifluid VOF too. Surface tension may be important but I'm not sure you need to worry about wall adhesion.
October 21, 2021 at 9:08 ami.tamunodienye2
SubscriberOk thanks. I will also check with the supervisor. He had specifically recommended VOF
October 21, 2021 at 12:02 pmDrAmine
Ansys EmployeeVOF is a capturing technique which is implemented in VOF Model and MultiVOF Model. At certai stage the VOF model is not enough and you need to deploy the more expensive MultiVOF. Details in the manual.
October 21, 2021 at 1:59 pmi.tamunodienye2
SubscriberI will follow with your suggestions.
Thanks
January 5, 2022 at 11:00 amfit78
SubscriberYou can refer to the following paper to simulate various type of wetting on tube wall. For fully wet the author used zero surface angle.
"Influence of the contact angle on the wettability of horizontal-tube falling films in the droplet and jet flow modes" Fernandez et. al (2018) - International Journal of Refrigeration
Viewing 11 reply threads- The topic ‘contact angle’ is closed to new replies.
6625
1311
