Why does the solved problem not give the stress contour plots?
    • Amirmkr
      Considering the following macro that is a static problem:
      /PREP7
      ET,1,BEAM188
      MPTEMP,,,,,,,,
      MPTEMP,1,0
      MPDATA,EX,1,,2.068e11
      MPDATA,PRXY,1,,0.3
      SECTYPE,  1, BEAM, CTUBE, , 0
      SECOFFSET, CENT
      SECDATA,0.055,0.065,4,0,0,0,0,0,0,0,0,0
      K, ,0,0,0,
      K, ,0.8,0.125,0,
      K, ,1.25,0.3,0,
      LSTR,    1,    2
      LSTR,    2,    3
      LESIZE,ALL, , ,10, ,1, , ,1,
      FLST,2,2,4,ORDE,2
      FITEM,2,1
      FITEM,2,-2
      LMESH,P51X
      FINISH
      /SOL
      ANTYPE,0
      FLST,2,1,3,ORDE,1
      FITEM,2,1
      /GO
      DK,P51X, ,0, ,0,UX,UY,UZ,ROTX,ROTY, ,
      NSEL,S, , ,   12
      DSYM,SYMM,Y, ,
      FLST,2,1,3,ORDE,1
      FITEM,2,3
      /GO
      FK,P51X,FX,-5000
      ALLSEL,ALL
      /STATUS,SOLU
      SOLVE
      When I want to plot the stress plots, it just gives the deformed geometry, all in red color. Why is that?
    • ErKo
      Stress results in beam elements are typically on the cross section so we need to show that cross section in our window - to do that issue
      /ESHAPE,1
      Then do
      set,last,last
      plnsol,s,eqv ! VM stress
      See eshape command in help for more info.
      All the best
      Erik
      • Chee Hui Ren
        Hi there, for my case I managed to get a contour ribbon. However, I couldn't show any contour on my beams. Could you please advise where can I set this up?
    • Amirmkr
      Thanks a lot Erik, that solved the problem, but why does the problem in the following link not need such procedure on cross section for stress plot?
      https://www.youtube.com/watch?v=1dvEmK6To7M
  • The topic ‘Why does the solved problem not give the stress contour plots?’ is closed to new replies.
