User Defined Results Mapping
    • Memin
      Hi all,
      I am using 2020 R1 Workbench. In Mechanical, I ran a prestressed Modal and gathered some results. With the results, I performed some custom hand calculations in Excel and gathered some new results. Now, I would like to map my customised results in Mechanical such as blue to red coloring range. ANSYS does not need to reanalyse or calculate anything. My external data is in csv format and includes only NODE ID and my customized numbers. ANSYS also does not need to know whether the new input is a temperature or a stress data, I only need to map my new results on my geometry to check my critical location based on my dimensionelss value. Could you please help?
    • Aniket Chavan
    • Memin
      Thanks a lot for your response, that's absolutely what I needed! Great :)
  • The topic ‘User Defined Results Mapping’ is closed to new replies.
