October 14, 2021 at 10:50 pm
khaledhmz12
Subscriberhello, I conducted a numerical simulation of propane-air using fluent, in the first case I use a chemical reaction mechanism contains 24 species and 66 reactions with species transport combustion model and Eddy dissipation concept for the net reaction rate with 79541 nodes (mesh size). the results obtained is predicted very well and the flame front is same with the experimental (figure1), but in the second case when I keep the same configuration as in case 1 and I only changed the mesh size to 151690, the flame temperature raised and its front changed (figure 2), and also its size being bigger than in the case 1,
I don't why this happen even I verified the B.C and the physics...
Can anyone help please
best,
November 11, 2021 at 2:25 pmRK
Ansys EmployeeHello,
How is the convergence for the finer mesh? Please make sure both the cases are converged well.
November 22, 2021 at 10:44 amkhaledhmz12
SubscriberHello, thank you for your reply
for the residual, I set 10 e(-5) for momentum, continuity, and every reaction equations and 10 e(-6) for the energy equation. the simulation run until 154000 iteration but the flame front don't change and the program doesn't stop, I'm really confused about it, any suggestion, please
best
December 22, 2021 at 9:44 pmkhaledhmz12
Subscriberhello, any help please I can't figure out this problem
December 22, 2021 at 9:49 pmRK
Ansys EmployeeMay I know what you mean when you say, program does not stop?
December 22, 2021 at 9:51 pmkhaledhmz12
SubscriberI mean the simulation doesn't converge and keep runing
Viewing 5 reply threads- The topic ‘Flame front don’t predicted accurately’ is closed to new replies.
5849
1305
