October 14, 2021 at 12:12 pm
fz.erraghroughi
SubscriberHello everyone!
I want to plot the streamwise velocity in different plans at a 90° bend pipe as shown in figure 1 below. I get the nonnormalized velocity at the entrance of the bend by taken the Y-axis as the radial direction (figure 2), but for the other plans (30° 60° 90°) it doesn't work! I think I need to create a local coordinate system for each plan. Is it possible to do this in Fluent or CFD post?
Any help, please!
Best regards.
figure1:
October 15, 2021 at 3:19 pmkarthik.remella
Administrator
What variable are you attempting to non-dimensionalize and what is your scaling parameter here? Could you please clarify?
Karthik
October 22, 2021 at 10:27 amfz.erraghroughi
Subscriberthanks for your reply!
I wanted to get non-dimensionalize the axial velocity at different plans! I solved that by creating a local coordinate system at each plan.
Regards.
October 22, 2021 at 1:55 pmRob
Forum ModeratorThe first & last planes align with x and z so that's easier. Otherwise you need to set the local cell zone axis up or use some trigonometry via a custom field function. I don't think Post has an automatic function for this, but don't know about Ensight.
October 28, 2021 at 11:48 amfz.erraghroughi
SubscriberI used the translate and the rotate options in Fluent to align my geometry with the plan that I want to plot my chart into it, then I export the point in a .excel file and compute my normalized velocity and r direction.
Thank you!
December 20, 2021 at 10:38 amViewing 5 reply threads- The topic ‘Non dimensional velocity in bends’ is closed to new replies.
