TAGGED: experimental-data, menetrey-william, parameters, softening
October 6, 2021 at 3:48 pm
MickMack
SubscriberHi guys,
I am validating my Menetrey William concrete model by replicating a compression test on a cylinder. The stress-strain curve i have created from the M-W model corresponds well with the experimental results as shown in the image below.
I was able to get uniaxial compressive strength and uniaxial tensile strength fromexperimental data. For the biaxial strenght and dilatancy angle i was able to source appropriate values from research literature.
However i cannot do this for the exponential softeneing used as it does not seem to be available. In my model i used parameters for exponential softening from another example, but of course i need to detail the rationale for choosing the value of each parameter in my research project.
Can anyone advise on how the parameters (shown below) for exponential softening are determined?
The parameters i used are shown at the end.
Thanks,
Michael
October 15, 2021 at 7:48 pmJohn Doyle
Ansys EmployeeBelow are a few reference publications that address concrete validation studies you might find helpful.
Calibration and Validation of the Menetrey-Willam Constitutive Model for Concrete; Dmitriev, A; Novozhilov, Yu; Mikhalyuk, D; Lalin, V. Stroitel'stvo Unikal'nyh Zdanij i Sooruzenij; St. Petersburg Iss. 3,(2020): 1-22. DOI:10.18720/CUBS.88.4
Model Code for Concrete Structures 2010. International Federation for Structural Concrete, 2013. ISBN: 978-3-433-03061-5, 434 p. Thacker, B.H., Doebling, S.W., Hemez, F.M., Anderson, M.C., Pepin, J.E., Rodriguez, E.A.
Concepts of Model Verification and Validation. Technical report, Los Alamos National Lab., Los Alamos, NM, United States. 2004. 28 p. DOI: 10.2172/835920.
Oreskes, N., Shrader-Frechette, K., Belitz, K. ; Verification, Validation, and Confirmation of Numerical Models in the Earth Sciences. Science. 1994. 263(5147). Pp. 641ÔÇô646. DOI:10.1126/science.263.5147.641.
September 28, 2022 at 11:02 am7121573
SubscriberHello Mr. MickMackÂI too have done compressive strength tests on the MW model and it does not show the same softening behavior as yours.After the peak there is an error of convergence.ÂI would appreciate it if you could tell me how you have succeeded in achieving the softening behavior, with respect to APDL and damping.April 20, 2023 at 3:35 pmDr. / Abdalla Mohamed
Subscriberhow to insert a stress-strain curve in compression and tension of concrete with Menetrey-Willam Model?
besides, I ask you is with Menetrey-Willam Model consider as a alternative to solid 65 regarding application of cyclic loading of RC elements and showing PINCHING effect ?
Viewing 3 reply threads- The topic ‘How to establish parameters for Exponential Softening with Menetrey-Willam Model?’ is closed to new replies.
3150
1013
945
858
797
