October 4, 2021 at 6:43 am
godaramohit10
SubscriberDear All
I started my drilling simulation but when it goes upto 17% to 20%, it is showing time step is too small. I have also watched ansys video mentioning about "Time Step Integration" and learn how to calculate total number of steps. But I don't know where to enter that value as in Ansys it is showing 3 types of time i.e. initial time step, minimum time step, and maximum time step.
Please help me.
Thanks in advance
October 4, 2021 at 8:43 pmChris Quan
Ansys EmployeeThe explanation of initial time step, minimum time step, and maximum time step can be found from ANSYS Help. See attached picture below.
Usually we suggest user to keep it as Program Controlled.
Since you are simulating drilling process, elements may get distorted during the process. The distorted elements will introduce small time step that could lead to time step too small error.
Thus, you need to make sure the Erosion Controls under Analysis Settings is on. The material model should include failure criterion as well so the material strength will not be over-predicted.
October 5, 2021 at 6:27 amgodaramohit10
SubscriberSir I did everything but still problem is there. can you please check my project and other than this I am also not getting any chip formation.
Please help
Thanks
October 8, 2021 at 3:04 pmChris Quan
Ansys EmployeePlease submit your questions as well as your model to ANSYS Tech Support for further diagnosis of the problem. Thank you.
January 7, 2022 at 8:29 pmShyam Prasad V Atri
SubscriberHi I am trying to do a tension test on a dog bone specimen with the material being polyurethane. I keep encountering this error of time step being too small. The same model works well with steel1006. Please let me know what parameter is called as time step and in the theory of explicit dynamics which parameter is time?
January 11, 2022 at 10:03 pmJanuary 11, 2022 at 10:03 pmShyam Prasad V Atri
SubscriberJust in case if you were not able to download it.
Viewing 6 reply threads- The topic ‘Error !!!! Time Step too small’ is closed to new replies.
6450
