September 18, 2021 at 10:41 am
sadiqamin475550
SubscriberI am using Ansys material Designer for making composite material properties from E glass chopped fibres and resins. But when I use a large aspect ratio (ratio of the length of fibre to its dia, in this case, l=25mm, dia=10 micrometre, aspect ratio=2500 ), the Spaceclain does not support the resulting geometry.
Please help me in this regard. How to overcome this problem?
October 15, 2021 at 7:21 pmSean Harvey
May I ask when you need to model 25 mm of fiber? This being a micro-mechanical model, we typically are not solving at that scale length for composites, unless there is something related to the specifics of your design. Do you have sketch you could share or details? Thanks.
Regards Sean
October 20, 2021 at 5:45 pmsadiqamin475550
SubscriberThanks. All I want is the elastic properties of short fibre chopped composite made of E glass fibre and a polyester resin. My fibre dia is 10um and fibre length is 25mm so my aspect ration becomes is in 1000s. How can I assume my aspect ratio to be 20 or 40 etc which the material designer normally support.
Viewing 2 reply threads- The topic ‘Space claim does not support Geometry in Material designer’ is closed to new replies.
3597
1243
1092
1068
953
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
