September 10, 2021 at 5:14 am
hajidjamal
SubscriberI read a research/report on how to determine rayleigh coefficient from modal analysis. how can we determine damping from modal analysis as it doesnt include any type of load? I need the rayleigh damping(alpha and beta) for me to conduct a transient analysis. Thank You.
September 10, 2021 at 11:10 ampeteroznewman
SubscriberModal analysis can't tell you the Rayleigh damping constants alpha and beta, those are inputs to a transient analysis.
An experimental modal survey can acquire data from instrumentation such as an accelerometer on a physical structure that is excited with a hammer strike or some harmonic excitation. Analysis of that data can calculate a damping ratio for each mode.
If you don't have that, then you can make an assumption on damping ratio based on the type of materials and joints in the structure.
There are equations to compute alpha and beta such that the damping ratio is fairly constant between two frequencies.
Those equations are explained in the free course on Damping on this site.
September 14, 2021 at 1:25 amhajidjamal
SubscriberThank you for the answer, if we mention type of material when conducting transient/harmonic analysis, does damping will occur in the result or we still need to input damping ratio(alpha/beta) in the analysis setting? thank you
September 14, 2021 at 3:48 ampeteroznewman
SubscriberEither add damping to the material in Engineering Data or add it in the Analysis settings. If you do both you will double the damping.
September 14, 2021 at 3:57 amhajidjamal
SubscriberBack to the first answer, so without doing the physical impulse hammer test, there are really no other way to determine the damping ratio for the damping ratio in the transient/harmonic analysis setting other than make an assumption on the dampin ratio? thank you
September 14, 2021 at 10:26 ampeteroznewman
SubscriberIn general, you need experimental data to provide inputs to simulation.
September 23, 2023 at 11:43 am
Hassan Elshokrofy
Subscriberif i have different structures made from the same material, can i do an experimenatal estimation of damping ratio for only one sample and use the result as input for FEA model for other structures?
Viewing 5 reply threads- The topic ‘How to determine rayleigh damping coefficient from Modal Analysis ?’ is closed to new replies.
6750
1325
1087
