September 6, 2021 at 4:02 am
sidharthasondh
SubscriberI am working on fixed bed reactor. I am giving the input for fuel via coal calculator. Giving input of Ultimate and proximate analysis. I have applied both homogeneous and heterogeneous reactions through species transport, but the problem is that I am not getting the desired concentration of the syngas. First i am generating the pdf and then i switch to species transport and apply all the reactions. Is there any option to input reaction temperature.
I am net in this field so kindly help me by providing your valuable feedback.
September 6, 2021 at 10:30 amRob
Forum ModeratorHow are you modelling the coal?
September 7, 2021 at 3:29 amSeptember 7, 2021 at 5:24 amDrAmine
Ansys EmployeeAnd the heterogeneous reactions? Is it only DPM model with species transport?
September 7, 2021 at 5:33 amsidharthasondh
SubscriberAfter generating the pdf from non premixed, i have selected species transport. In that taking pdf as the mixture i apply both homogeneous and heterogeneous reaction.
September 7, 2021 at 5:40 amDrAmine
Ansys EmployeeHow are you modeling the heterogenous reactions? Which models are enabled in your case?
September 7, 2021 at 7:12 amsidharthasondh
SubscriberDiscrete Phase Model is there that i have used. I am not aware of so many models. It would be a great help if you could guide me through in this. I am working on a simulation for Lignite coal gasification and i wish to calculate the concentration of products from the whole process.
September 7, 2021 at 9:04 amRob
Forum ModeratorDPM for a packed/fluidised bed isn't going to work: read the assumptions on that model. I think you'll need the Eulerian model, and may then need to review the chemistry.
September 7, 2021 at 9:06 amsidharthasondh
SubscriberThanks rob. Are there tutorials on eulerian model.
September 7, 2021 at 9:18 amRob
Forum ModeratorI think so. Check in Help, otherwise there is one in the Learning Hub (you need to pay for that) on the Multiphase course.
Viewing 9 reply threads- The topic ‘Coal Gasification in fixed bed reactor’ is closed to new replies.
6405
