TAGGED: 2d-axisymmetric, axisymmetric, designmodeler, geometry
September 3, 2021 at 10:59 pmrajendraporSubscriber
I wish to create an axi-symmetric model for a vertical pipe. How can I make the body to rotate about Y- axis. I saw in many posts that, axis of symmetry is x-axis for fluent and cannot be changed.
September 6, 2021 at 11:03 amRobForum ModeratorYou don't move the geometry, you move the world: gravity also has a vector.
September 6, 2021 at 2:37 pmrajendraporSubscriberThanks! I figured out about the setting of fluent, after getting divergence. Just changed the vector_g to +x direction. Physics remains the same.
Actually many threads are there where people wrote about getting divergence in axi-symmetric models. This is one of the primary reasons.
September 6, 2021 at 4:16 pmRobForum ModeratorIt is, the secondary reason is having mesh in the y<0 position. Just remember that gravity ****, so if "up" is positive x the gravity vector is -9.81 Getting that one wrong is another very common mistake.
September 7, 2021 at 3:31 pmrajendraporSubscriberThanks again! Very right. Hope this thread may help someone getting some errors due to these reasons.
Viewing 4 reply threads- The topic ‘AXI-SYMMETRIC DOMAIN FOR VERTICAL PIPE.’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Fluent fails with Intel MPI protocol on 2 nodes
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- UDF, Fluent: Access count of iterations for “Steady Statistics”
- RIBBON WINDOW DISAPPEARED
Top Contributors-
1421
599
591
565
366
