Which theorem is Ansys using in the background for bending?
    • ozdmrdnz
      Hello everyone,
      I was trying to modelled sandwich panel composite beam for three point bending test but I dont know which theorem is ansys using for background by the way I am trying to find total displacement . Also should I modelled my composite face solid or sheel which one is the more accurate ? or should I modelled my core for solid and the other faces for sheel ?
      Best Regards
    • ozdmrdnz
    • ErKo
      Hi
      We can use solid 3D elements (if the model is not too large), or solsh190 elements - it depends if you are looking at only displacement or if you want a very accurate through thickness stress distribution (so stresses perpendicular to the shell surface), or shear distribution then a solid might be needed. Of course if the model is very large (and thin), then using solid 3D elements might be too heavy computationally.
      Shell elements might be OK for a global shell model assuming it is not too thick (moderately thick) - see shell181 for more info on our shell elements. SO it all depends, on what we are looking at and are after (results).
      There are also many discussion on the internet on this:
      Also use a search engine and look for a discussion called:
      Comparison of ANSYS elements SHELL181 and SOLSH190
      This will give some good guidelines on what to use and what to watch out for.
      All the best
      Erik
    • ozdmrdnz
      Thank you for all kindly recommandation Erik It was very useful
      Best Regards
  • The topic ‘Which theorem is Ansys using in the background for bending?’ is closed to new replies.
