Failed to choose the register in the The Patch Dialog Box with TUI Commands
    • Stemphanie_anansu
      HI:
      I am faced with the problem to choose the register in the The Patch Dialog Box with TUI Commands.
      I tend to change the the value of the temperature from 0 K to 2000 K
      and the TUI command "/solve/patch/ _ cell_register_0 _ temperature n 2000" is used
      however, I failed to choose the register  :
      Is anything wrong with my command?
      or should I add another command?
      (Ansys 2020 R1)
    • Rahul Kumar
      Use /solve/patch () (cell_register_0) temperature 2000
    • Amine Ben Hadj Ali
      Start using the Search Feature in Fluent to quickly find out the right command ( top left)
    • Stemphanie_anansu
      thank you
    • 1829116
      Hi
      What TUI should i use to patch the part-steeel_tube to 30 C?
Viewing 4 reply threads
  • The topic ‘Failed to choose the register in the The Patch Dialog Box with TUI Commands’ is closed to new replies.
