August 12, 2021 at 9:33 am
Timur97
SubscriberHello,
I´m currently searching for a tool to solve a problem. It is neccessary for me to identify the smallest possible contact area between two objects. These two objects might have a soft surface or they might be solid. It is neccessary to take in account contact from all object dirrections but also contact in various relative position to each other. The only outcome I need to know is the contact area. Do you think this might work in Ansys and if yes, what would be the overall strategy to implement this kind of thing?
Thank you for your help and answer!
August 24, 2021 at 1:14 amAshish Khemka
If you are trying to identify any possible contact location and not miss out on the same then you can change the Tolerance Settings under Contact Auto Detection:
Mesh Connection Group/Contact Match Group (ansys.com)
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘Is it possible to identify the smallest possible contact between two objects in Ansys’ is closed to new replies.
6625
1311
