August 11, 2021 at 7:21 am
afshiin.a
SubscriberHello
I want to simulate an Add-drop microring resonator in the MODE module and get the results of the S parameters. I can not use the FDTD module due to lack of hardware.
How to calculate S in the MODE module? Does it have a script? If the answer is yes, please guide the exact script.
Thanks.
August 11, 2021 at 8:59 pmGuilin Sun
Ansys EmployeeDo you want to get the S parameters for the whole device (buses + resonator)? and what is the next usage of the result? If I know this, I could give you more direct answer.
You can use varFDTD: https://support.lumerical.com/hc/en-us/articles/360042800233-Ring-resonator-getting-started-Parameter-extraction-and-Monte-Carlo
Here is some analysis https://support.lumerical.com/hc/en-us/articles/360042800293-Ring-resonator-getting-started-Design-and-initial-simulation
more: https://support.lumerical.com/hc/en-us/articles/360043164634-Photonic-integrated-circuits-Passives-list-of-examples
If it is later used in INTERCONNECT, you do not need to simulate the whole device: https://support.lumerical.com/hc/en-us/articles/360042323794
August 15, 2021 at 2:48 pmafshiin.a
SubscriberThanks a lot
Viewing 2 reply threads- The topic ‘S parameter for Ring resonator in the MODE (varFDTD)’ is closed to new replies.
6435
