Ansys Products
Ansys Products
Meshing Issue – Failed determining temp directory location
    • jenkinsc
      When starting the meshing application (even with old meshes I have already meshed), I get a series of error messages, including "Failed determining temp directory location!" and error code 80004005. The issue is only with the meshing application, as I can still open setup, solution, and results for CFX with pre-generated meshes.
      There are two solutions I have seen online:
      1. Create an ansysdata folder for your work and make sure that your file and username are alphanumeric
      2. Go to the %appdata% location in file explorer, open the Ansys folder, rename "v211", and restart the workbench
      Neither of these two solutions has worked for me. Does anyone have any other possible solutions?
    • Rahul Kumar
      In WB, please go to Tools and determine the temp location. If need be, you can change it and it will take affect when you restart WB.
  • The topic ‘Meshing Issue – Failed determining temp directory location’ is closed to new replies.
