August 6, 2021 at 6:15 pm
nikhilvarma
Subscriberafter installing 2020r2 student version i am unable to open mechanical apdl and even workbench and keep on getting the license error message so can any one help me with this i am helpless and its mandatory for me to use only 2020 r2 student version
August 6, 2021 at 6:52 pmANSYS_MMadore
Forum ModeratorPlease uninstall and then delete the entire C:\Program Files\Ansys Inc directory. Now redownload 2020R2 and reinstall.
August 6, 2021 at 6:53 pmnikhilvarma
Subscriberdid it more than 5 times but the same problem keep arising
August 6, 2021 at 6:54 pmANSYS_MMadore
Forum ModeratorOpen a Windows command prompt and type "set" without quotes and post the full output.
August 6, 2021 at 7:16 pmnikhilvarma
Subscriberhere is what i got when i did set in windows command prompt
August 6, 2021 at 7:18 pmANSYS_MMadore
Forum ModeratorPlease copy and paste the full text of the output into a reply.
August 6, 2021 at 7:25 pmnikhilvarma
SubscriberMicrosoft Windows [Version 10.0.19042.1110]
(c) Microsoft Corporation. All rights reserved.
C:\Users\nikhi>set
ALLUSERSPROFILE=C:\ProgramData
ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
ANSYS_SYSDIR=winx64
APPDATA=C:\Users\nikhi\AppData\Roaming
AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=NIKKY
ComSpec=C:\windows\system32\cmd.exe
DriverData=C:\Windows\System32\Drivers\DriverData
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
HOMEDRIVE=C:
HOMEPATH=\Users\nikhi
LOCALAPPDATA=C:\Users\nikhi\AppData\Local
LOGONSERVER=\\NIKKY
LSTC_LICENSE=ANSYS
NUMBER_OF_PROCESSORS=8
OneDrive=C:\Users\nikhi\OneDrive
OneDriveConsumer=C:\Users\nikhi\OneDrive
OnlineServices=Online Services
OS=Windows_NT
Path=C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Users\nikhi\AppData\Local\Microsoft\WindowsApps;
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
platformcode=KV
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 140 Stepping 1, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=8c01
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\windows\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
RegionCode=APJ
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\windows
TEMP=C:\Users\nikhi\AppData\Local\Temp
TMP=C:\Users\nikhi\AppData\Local\Temp
USERDOMAIN=NIKKY
USERDOMAIN_ROAMINGPROFILE=NIKKY
USERNAME=nikhi
USERPROFILE=C:\Users\nikhi
windir=C:\windows
ZES_ENABLE_SYSMAN=1
C:\Users\nikhi>set
ANSYS_SYSDIR=winx64
COMPUTERNAME=NIKKY
HOMEDRIVE=C:
LOGONSERVER=\\NIKKY
LSTC_LICENSE=ANSYS
OS=Windows_NT
platformcode=KV
PROCESSOR_LEVEL=6
PROMPT=$P$G
RegionCode=APJ
SESSIONNAME=Console
SystemDrive=C:
USERDOMAIN=NIKKY
USERNAME=nikhi
windir=C:\windows
ZES_ENABLE_SYSMAN=1
C:\Users\nikhi>
August 6, 2021 at 7:32 pmnikhilvarma
Subscribercan i get my problem solved
August 6, 2021 at 7:42 pmANSYS_MMadore
Forum ModeratorIf you completely uninstall and delete the C:\Program Files\Ansys Inc directory, then download the 2020R2.1 installer it will have a valid license to 1/31/22. When installed there should not be any license file in the C:\Program Files\Ansys Inc\Shared Files\Licensing directory, or reference to a file in that directory when running it. Please also try deleting your %APPDATA%\Ansys directory.
August 6, 2021 at 8:02 pmANSYS_MMadore
Forum ModeratorCorrection, there WILL be a student.lic file in D:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing, with an expiration of 1/31/22.
Viewing 9 reply threads- The topic ‘ansys student 2020 r2 license manager error’ is closed to new replies.
3582
1193
1086
1063
952
