August 4, 2021 at 7:37 am
ejlee0911
SubscriberHello.
I have a question to make a circular polarization source. If you don't mind please help me.
I checked the plane wave sources can make circular polarization source.
August 4, 2021 at 8:12 amejlee0911
SubscriberOh. I got how to get this.
In this case, I must use magnetic dipole and electric dipole, with parallel direction!
August 4, 2021 at 4:31 pmGuilin Sun
Ansys EmployeeI am glad to know that you find the answer by your own. Circular polarization from dipoles are new concept recently which is not fully well defined uniquely as the same as in traditional concept which has a clear direction of travel. Please verify that it meets your expectation.
Viewing 2 reply threads- The topic ‘circular polarization light using dipole source’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Difference between answers in version 2024 and 2017 lumerical mode solution
- Import material .txt file with script
- Absorption cross-section of AuNR excited by prism-based TIR
- How to measure transmission coefficients on a given plane .
- TE Polarization Fraction + Waveguide TE/TM Fraction
- Edge Coupler EME Example Issue
- Lumerical Python API Topology Optimization Error 2025 R1
- 2D inverse design grating coupler
- FDE : Simulation waveguides with electrodes
- Loss of lithium niobate phase modulator
Top Contributors-
2432
930
599
591
569
