July 29, 2021 at 3:10 pm
rohith123
SubscriberHello guys I have a doubt and I need your help.
I have two flanges one of steel and other composite and they are fastened. They have different coefficient of thermal expansion hence thermal stresses are induced. How to overcome it?
Please reply to this.
July 30, 2021 at 4:11 pmdlooman
Ansys EmployeePerhaps a flexible gasket between the two flanges will permit differential expansion of the flanges. It's not really an Ansys question is it?
July 30, 2021 at 4:20 pmrohith123
SubscriberNope its not a ansys question..But this place is for sharing knowledge and discussion ..so i thought of posting here..Thanks for your response.
July 31, 2021 at 2:01 pmpeteroznewman
SubscriberIf you provide more information such as an image of the steel part and the composite part, you might get a more relevant answer. Flanges suggests pipes are involved as 's reply implies. I'm going to assume that "flanges" are flat circular features on bodies that are not pipes.
One configuration to rigidly connect two flanges with different CTE values and have no thermal stress is to use a Hexapod strut mount. This image shows adjustable struts, which are useful for precisely aligning one body with the other, but if you don't need adjustment. you can have fixed length struts.
Viewing 3 reply threads- The topic ‘Differential thermal expansion’ is closed to new replies.
5864
1306
