July 28, 2021 at 12:43 am
ha_nguyen3
SubscriberI want to study the changes in electric field across the geometry when applying 42V at 200kHz. I'm currently using Ansys Discovery Aim. I select electromagnetic simulation for this study.
July 28, 2021 at 1:25 pmNaresh Patre
Ansys EmployeeHello ha_nguyen3
Voltage option is not available in AIM.
Regarding Skin Depth Resolution, the help document mentions the following:
You can add aSkin Depth Resolutionphysics option to generate a mesh that's more dense for selected locations near the surfaces of conductors, where Eddy current effects are more significant, thus avoiding the need to generate a very large, dense mesh for all surfaces.
Select one or more faces for theSurface locationfor which you want to specify askin depth resolution.
Set theResolutionslider to one of the eight settings to control the initial mesh resolution for the selected location.
In general, the finer the setting, the denser the initial mesh will be, and the more accurate the solution, but at the expense of increased computation time.
Viewing 1 reply thread- The topic ‘Electromagnetic Simulation – Skin depth resolution’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Co-simulation in Q3D, Icepak – meshing problem
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
Top Contributors-
4597
1500
1386
1209
