July 25, 2021 at 3:52 pmethanbanana1Subscriber
Hello
I am having some issues with ANSYS Spaceclaim and importing IGES files. Im currently working on designing a frame for my FSAE team so I have been importing the frame sketch geometry from Solidworks to ANSYS Spaceclaim as an IGES file. In the past the 3D sketch of the frame will import with a bunch of surfaces for each frame tube. But now only the surfaces will import and I cannot see the 3D sketch anymore.
I need to have the 3D sketches for this simulation because I need to be able to apply tube size and material to sections of the frame.
It has worked for me in the past which is why I am confused. I tried multiple different frame files and all of them will not import or display any of the 3d sketches in ANSYS Spaceclaim.
Is there a display option that I could be missing or something within the IGES settings?
When I export the frame file from Solidworks as an IGES, I made sure to check the box that says "export 3d sketch entities"
Thanks
August 3, 2021 at 10:22 amKeyur KanadeAnsys EmployeeCan you please add some images here
For IGES options you can check File --> SpaceClaim options.
Please go through help manual for more details
Regards Keyur
How to show full resolution image
How to use Google to search within Ansys Student Community
September 21, 2022 at 10:50 amAbdul HSubscriberTry going to Repair tab > Stitch, creating solid bodies from the surfaces.
Viewing 2 reply threads- The topic ‘Importing Spaceclaim geometry as IGES’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
Top Contributors-
1311
591
569
525
366
