July 15, 2021 at 8:13 am
rickm98
SubscriberHello experts,
because I can't make this simulation work I wanted to ask if it is even possible to simulate the doctor blading process in Ansys Fluent or by system coupling. In this process a doctor blade (orange) pushes the viscous Fluid (green) into a cavity. I think the deformation rate of the fluid is too high but maybe someone has an idea how to make it work.
Regards
July 15, 2021 at 9:07 amAmine Ben Hadj Ali
Ansys EmployeeInsert your picture in your text. _What do you mean you cannot make simulation work?
July 15, 2021 at 11:07 amJuly 15, 2021 at 11:09 amRob
Forum ModeratorAssuming the pale blue block is the blade, where is the fluid region?
July 15, 2021 at 11:18 amrickm98
SubscriberIn this process a blade (orange) pushes the viscous Fluid (green) into a cavity.The block should get deformed by the blade.
July 15, 2021 at 12:09 pmAmine Ben Hadj Ali
Ansys EmployeeSo Orange is a solid blade which needs to push the green fluid. How are you accounting for that in Fluent?
July 15, 2021 at 12:51 pmrickm98
SubscriberThat's what I'm not sure of. At the moment I think Ansys Fluent is the wrong software for this simulation but I thought maybe i am missing something
July 15, 2021 at 12:54 pmAmine Ben Hadj Ali
Ansys EmployeeDo you want to model the fluid dynamics in the "green" fluid domain or just want to account for deformations of the green domain?
July 15, 2021 at 12:57 pmrickm98
SubscriberI want to account for deformation of the green domain
July 15, 2021 at 1:03 pmRob
Forum ModeratorWhat sort of fluid is the green block? Note, there are two green blocks so I am assuming it's the one next to the orange one.
July 15, 2021 at 1:08 pmrickm98
SubscriberIt has nearly the properties as honey and yes you are assuming right.
July 15, 2021 at 1:10 pmAmine Ben Hadj Ali
Ansys EmployeeShould be doable with Fluent providing you have the right material viscosity and taking care about the numerics of transfer of displacements and forces :)
July 18, 2023 at 9:31 amTanmay Chitnis
SubscriberHi, can you please explain this in detial, how is this possible to model in Fluent?
TIA
Viewing 12 reply threads- The topic ‘Is it possible to simulate high fluid deformation in Ansys Fluent?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3912
1414
1256
1118
1015
