TAGGED: 2D, ansys-workbench, heat-flux, jet, turbulent
July 9, 2021 at 9:43 am
Golaselo
SubscriberHello everyone, I am moddeling Jet Impingement Heat Transfer in the pipe (2D). I know I have to modyfiy the energy equation to include element responsible for turbulent heat flux. Can anyone help me with this, give some tips?
Best regards, WG
July 9, 2021 at 11:44 amaitor.amatriain
SubscriberTurbulent heat flux is included by default when a turbulence model is used. If you need to include a different term than the "typical one" (i.e., with a turbulent thermal conductivity), please post the expression here.
October 6, 2021 at 5:49 pmGolaselo
SubscriberHello Aitor, could you help me with modyfying energy equation in Ansys?
October 7, 2021 at 6:45 amaitor.amatriain
SubscriberWhich term do you need to include?
October 7, 2021 at 7:10 amOctober 7, 2021 at 7:58 amaitor.amatriain
SubscriberAssuming that a is constant, I would say that the correct expression of the energy equation is as follows:
This is the equation that is implemented in Ansys Fluent. What is your closure for the turbulent heat flux? The typical approach for the turbulent heat flux is based on introducing the turbulent thermal conductivity, and in that case you do not have to do anything, as it is implemented by default.
October 7, 2021 at 9:00 amGolaselo
SubscriberSo, to summarize. I am using standard energy equation in fluent and when I use any kind of turbulence model (k-epsilon and k-omega in my case) this term (the last in equation) is included in it. Is that correct?
October 7, 2021 at 11:10 amDrAmine
Ansys EmployeeYes.
October 11, 2021 at 11:43 amGolaselo
SubscriberHello again, could you tell me how to write an UDS for implementing anisotropic turbulent heat flux? I read it from this article.
https://www.epj-conferences.org/articles/epjconf/pdf/2015/11/epjconf_efm2014_02063.pdf
October 11, 2021 at 2:28 pmDrAmine
Ansys EmployeeFluent does offer a way to define anisotropic UDS diffusivity.
November 21, 2021 at 11:02 amGolaselo
yes, I would like to get turbulent heat flux with turbulent thermal conductivity. I got information from my professor that I have to write an UDF to get that. It is possible to calculate it in another way, but I have to get turbulent heat flux directly from ANSYS by using UDF, could you give me some advices?
Viewing 10 reply threads- The topic ‘Modification Energy equation to include turbulent heat flux.’ is closed to new replies.
6635
1312
