July 3, 2021 at 5:33 pm
jccubi
SubscriberJuly 9, 2021 at 12:34 pmGeorge Karnos
Ansys EmployeeTry the following:
Shut down all Ansys Programs.
Browse to: %APPDATA%
rename the Ansys directory to Ansys.old
Try to run again.
July 10, 2021 at 9:37 pmjccubi
SubscriberDear Geo
Thanks for your kind reply but unfortunately did not work. After changing the name of the folder as you suggested, another file in the AppData/Roaming directory is created when Ansys runs again but the problem continue. Besides, after making some changes, a second problem appeared. I was able to solve the second problem but I am not sure how because I changed some options in Ansys and Space Claim configuration,
It seems that the problem appears in the Ansys student version 2021 R.1. I installed it in another computer and the same problem appeared.
Regards
Viewing 2 reply threads- The topic ‘Why I get the following error message each time I send to workbench the geometry from spaceclaim?’ is closed to new replies.
3597
1243
1092
1068
953
