June 21, 2021 at 12:09 pm
aslzynperl
SubscriberHello,
I'm currently realising a simulation of a stator and I got the force applying on each slot as a function of time in a .xls file. How can I import that force to the Harmonic Response module ?
Thanks for your attention.
June 21, 2021 at 1:13 pm1shan
Ansys EmployeeHarmonic response gives you the steady state response of a structure to sinusoidally applied load at different frequencies. That said you can import a force vs frequency load as a tabular data in a harmonic analysis. If you want the response with respect to time you need to do a transient analysis where you can apply a time dependent load. Simply insert force>click magnitude>tabular data and copy the column data from .xls file.
Regards Ishan.
June 22, 2021 at 11:40 amaslzynperl
SubscriberIt worked perfectly. Thanks a lot.
Best regards
Zeynep
Viewing 2 reply threads- The topic ‘How can I import Excel data to ANSYS Harmonic Response ?’ is closed to new replies.
6660
1313
