Flow boiling of hydrocarbon in a small channel
    • engrtahir1
      I have simulated the flow boiling of liquid hydrocarbon in a small channel. The axial symmetry was used and VOF method with phase change method is used. The boiling is induced by temperature boundary.
      The results are good, but i want to know one thing
      How the heat flux is calculated in case of two phase flow. When the two liquid and vapor are separated by a liquid-vapor interface.
      How the heat flux is calculated in this case.
      I need very urgent help in this matter please.
      The heat transfer is covered in the documentation, however, remember that VOF has a single energy equation solved for both phases.
    • engrtahir1
      Thanks.
  • The topic ‘Flow boiling of hydrocarbon in a small channel’ is closed to new replies.
