TAGGED: 3-phase, eulerian-model, mixture, multiphase-flow
June 17, 2021 at 9:32 am
monsboerns
SubscriberHello Fluenters!
I am currentrly using Ansys Fluent 2020 for my CFD calculations. Now I faced a problem regarding muliphase flows that I can't solve.
My question now is: Is there a way to model 3 phases, where phase 1 (plastic) is dispersed as droplets in a continuous phase 2 (also plastic) and these two phases together are surrounded by another continuous phase 3 (air)?
Thank you all in advance for answering my question!
Best regards.
June 17, 2021 at 9:46 amDrAmine
Ansys EmployeeYes you can do that. Eulerian Multiphase in Fluent does only have one primary "continuous phase". That is how it is built. To have another "continuous" phase you need to provide a dummy diameter (stick to default) and just balance the whole thing via Drag and Interfacial Area.
How big is the volume fraction of the plastic particles (thinking about using DPM for that as alternative).
June 13, 2023 at 3:36 am
azim
SubscriberHi DrAmine and Monsboerns,
I know I am very late in this discussion, but can you please elaborate a little bit?
Azim
June 17, 2021 at 9:54 ammonsboerns
SubscriberHello DrAmine first of all, thank you very much for your fast answer, that helped me a lot!!
If I understand you correctly I just use "Mixture" as multiphase model, use 3 phases and choose my diameter in a way that the drag force between air and the other continuous plastic phase is very huge, that it cannot penetrate the other phase?
The volume fraction of the dispersed phase is actually very big (50/50), so the Eulerian/Eulerian model suits me best, as I am not interested in the flow behaviour of the particles themselves.
Thank you in advance for answering my question
Best regards.
Viewing 2 reply threads- The topic ‘3 Phases with one dispersed’ is closed to new replies.
5824
1305
