June 14, 2021 at 5:07 pm
rybask1
SubscriberI have been using LS Dyna for about 2 years, and now my university has transitioned from LS-Run to ANSYS as our primary solver for LS Dyna. I have created countless .k files surrounding Toyota's THuMS model, and I need to be able to run them in ANSYS. However, ANSYS does not recognize the geometry from any of the .k files, and LS PrePost will not export the geometry of the THuMS model into an IGES, because it says there are 'no geometry entities in this model'.
Is there any way I can either solve the .k file directly through ANSYS or export the geometry using a .k file? Any leads are greatly appreciated.
June 21, 2021 at 12:29 pmRam Gopisetti
Ansys EmployeeAs of current build of ANSYS and ANSYS WB, Few Material models, FEA Bodies( springs , dampers, beams, e.t.c) are not supported. So importing the .k file into the ANSYS environments will give you error or with few build it might load forever with possible freezing.
Cheers, Ram
June 21, 2021 at 1:08 pmrybask1
SubscriberI keep getting ÔÇ£Unknown License ErrorÔÇØ.
Is there a source where I can see which FEA bodies and materials are supported by ANSYS?
Viewing 2 reply threads- The topic ‘How can I get geometry from a .k file (ie. Toyota THuMS) into an ANSYS project?’ is closed to new replies.
6745
1324
1047
