June 14, 2021 at 8:09 am
charlieoscarpapa_
SubscriberI need any kind of measurement that can be evaluated as a results after impact. Either the value of Impact Energy, minimum & maximum value of Absorption Energy, Velocity value before & after impact or anything that can be use as a results for impact energy.
June 14, 2021 at 5:05 pmAkshay Maniyar
You can right-click on the solution andInsert>Deformation>Total VelocityorDirectional Velocity. You can scope it to the body as needed.
I have given drop height as 500 mm, that means impact velocity will be 3131 mm/s. If you plot total velocity as described above you will get velocity after impact also.(shown in 2nd image)
regards
amaniyar
June 15, 2021 at 7:48 amcharlieoscarpapa_
There are too many different values shown in the results. which one is the value of velocity after impact ? *p/s : my initial velocity is 35.357m/s so supposed to be maximum velocity is 35.357m/s as well right ? so which one is the minimum value to show the velocity after impact ? or should i take the average value in the table ? I'm looking forward for your consult, tq.
June 15, 2021 at 8:55 amAkshay Maniyar
If you have scoped it to a body that means it is a bunch of nodes and it would always pick a min, max and average them out. The scope can be all bodies, one body, one face, one edge or one vertex. If you scope one vertex there is a single value for max, min and average.
Generally we consider average value.
regards amaniyar
Viewing 3 reply threads- The topic ‘Can i get the value of impact energy in Explicit Dynamics ?’ is closed to new replies.
6485
