Nusselt number
    • Abubakar
      Can anyone tell me the real significance of Nusselt number? And how as CFD engineer it will going to help me? I have read 2 to 3 books but in that only definition is there.
      Thank you,
      Abubakar khan
    • ai0013
      As many other dimensionless numbers in transport phenomena, the Nu number compares the strength of two mechanisms in the context of heat transfer, namely: Convection / Conduction. In practice, just as the Re number indicates how turbulent your flow is (its nothing but the ratio of advection over diffusion-viscosity effects), the Nu number indicates which heat transfer mechanism is dominant in your system.
      Look at the terms in the definition of the Nu number:
      Nu = h * L / k
      h= convective heat transfer coefficient (W/m┬▓ K)
      L = characteristic length in your system (m)
      k: thermal conductivity (W/m K)
      Depending on the application, there are different correlations (typically based on Re and Pr) that help you to estimate the Nu number. These correlations are derived for specific cases and take into account the boundary layer, momentum, viscosity effects, etc..
      So at the end of the day you will have something like
      Nu = f(Re,Pr) = h * L / k
      from which you can derive the convective heat transfer coefficient (HTC). Please look at https://en.wikipedia.org/wiki/Nusselt_number or read Incropera's book.
    • Abubakar
      Thank you so much for the brief explanation Now I understood its significance.
    • DrAmine
      Good
  • The topic ‘Nusselt number’ is closed to new replies.
