June 8, 2021 at 10:21 pm
leonardopicinin12
SubscriberHi everyone, I would like to know if it is possible to define a cut surface with the "section plane" tool as the "geometry" that I want to see the results of. In the following example, I would like to know the average strain on the highlighted surface. This body was cut with the "section plane" tool. I also selected another face, to demonstrate which "tool" I would like to apply to the face highlighted with the arrow. Thank you in advance for your help.
June 9, 2021 at 11:10 amAshish Khemka
Please see if the following post helps:
Regards Ashish Khemka
February 28, 2023 at 11:14 am
Boonyanuch Suksawang
SubscriberI have similar issue but the link you provided seems to be broken. Could you repost the link?
Thank you in advance.
June 9, 2021 at 11:40 pmleonardopicinin12
SubscriberThanks, that's exactly what I was needing
Viewing 2 reply threads- The topic ‘Get the average stress of a section using the “section plane” tool’ is closed to new replies.
5824
1305
