June 5, 2021 at 9:28 pm
karolasz
Subscriberhi, sorry in advance if that is wrong category, but is this calculator correct? {Link removed as a Google search tagged a weight loss blog! @Rob } I need to calculate 10kg to lbs and i'm not sure if this outcome is good
June 6, 2021 at 8:44 pmDavid Mercier
Ansys EmployeeHi, there are multiple other websites where you can check whether the conversion is correct, like for example here: https://www.unitconverters.net/weight-and-mass/kg-to-lbs.htm.
January 12, 2022 at 2:41 pmlinkSys
Subscriberkg × 2.20462 = lbs, so 10kg x 2.20462 = 22,046 lbs (rounded to three decimals), example https://calculatewithchris.com/10-kg-to-lbs
January 12, 2022 at 3:17 pmNovember 28, 2023 at 9:55 amDonald Brown
SubscriberHere is one more all-to-all converter https://oneconvert.com/unit-converters/weight-and-mass-converter/kg-to-lbs hope it helps in furthure convertion issues;)
Viewing 4 reply threads- The topic ‘converting from kg to lbs?’ is closed to new replies.
6810
1343
1152
