June 3, 2021 at 9:47 am
abhaymh
SubscriberI have the requirement of changing the input velocity based on the EWF thickness which is a result of the simulation, based on an equation. I wanted to know how I could read the value of the film-thickness into the UDF in order to manipulate it.
June 3, 2021 at 11:34 amRob
Forum ModeratorYou may be better off using an expression as that can take the film thickness at a position as a Report. There will be an equivalent UDF macro, so check the manual. Expressions are a newer feature in Fluent (based on CFX technology) as a means to avoid needing UDFs for "simple" stuff.
June 3, 2021 at 11:40 amabhaymh
SubscriberI can use the expression, yes, but here's what I have to do: Use film thickness to calculate a value, then use that value to calculate the flow rate and subsequently the velocity at the flow inlet. For this, I think I will have to use a UDF since the value changes at every iteration. Is it possible to accomplish this using just expressions?
June 3, 2021 at 1:58 pmRob
Forum ModeratorYou can do that with expressions, that's one of the functions they're designed for. Just make sure the expression makes sense for a zero thickness film.
June 10, 2021 at 7:37 pmabhaymh
SubscriberThank you. While that works to define it, it says invalid expression. As you can see from the image, the expression does give a value in the plot. I'm not sure if I've made a mistake or something.
EDIT: I've also attached a plot for changing values of film thickness (it makes sense, realistically speaking)
June 11, 2021 at 10:58 amRob
Forum ModeratorWhat is evap_area?
Viewing 5 reply threads- The topic ‘Fluent UDF – Reading a variable that is generated during the simulation’ is closed to new replies.
3712
1313
1163
1090
1014
