June 2, 2021 at 6:32 pm
twscfltx
SubscriberIs it possible to change from Shell 181 to Shell 281 on existing mesh? I've tried EMODIF and receive error of  Element 1 has an undefined node number 0. Not sure how to or if I can change mesh to quadratic, or if I have to remesh.
June 3, 2021 at 6:17 amErik Kostson
Ansys EmployeeIt is better to remesh - if you are using WB/Mech., the use a quadratic mesh option (element order), or in apdl before meshing (AMESH command), issue type,type number for el. 281.
all the best
Erik
June 3, 2021 at 7:41 am1shan
Ansys EmployeeHave a look at /forum/discussion/5082/error-in-changing-element-type. Use "et,matid,281" and change the element order to quadratic.
Regards Ishan.
June 3, 2021 at 10:05 amtwscfltx
SubscriberI saw that discussion for workbench. How do you change the element order in apdl or mechanical classic? Thank you in advance.
June 3, 2021 at 10:09 amErik Kostson
Ansys Employee@twscfltx
it is best to mesh straightaway with 281 elements as we said so:
et,1,281
type,1
... add sections, mp,..
AMESH, ! mesh areas
/SOLU
and the mesh will be using 281 elements.
All the best
Viewing 4 reply threads- The topic ‘Changing Element Type from Shell 181 to Shell 281 on existing mesh’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3907
1414
1256
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
