May 25, 2021 at 5:21 am
UsamaKhan
SubscriberMay 25, 2021 at 12:53 pmAshish Khemka
This generally happens when the project is corrupted. Try restoring the model using the Mechanical Database. In Mechanical, exported the .mechdat fie, then reimport into a new object on the schematic.
In your project folder, there should be an SYS.mechdb file for each Analysis object that was on the schematic ( the location for .mechdatis indicated in the error message). - Make a copy of SYS.mechdb to another folder Rename the copy to SYS.mechdatCreate a new Project. File > Import change the extension filter to .MECHDATBrowse to the SYS.mechdatand open. Save the project to a new name/folder when you are done.Also, please avoid having spaces in the file name.Once the .mechdatfile is imported you can resolve or import the result file (if you have it).
Regards Ashish Khemka
May 25, 2021 at 5:58 pmMay 26, 2021 at 7:50 amMay 26, 2021 at 7:26 pmUsamaKhan
Right but when i connect it with electromagnetic suit or maxwell a pop up shows geometry is already exsist. how can i test thermal effect in maxwell ?
May 27, 2021 at 9:45 amAshish Khemka
Please see if the following links help:
May 27, 2021 at 10:27 amUsamaKhan
Thankyou soo much its much informative but can we test thermal analysis in 2D as i have seen all are explaining in 3D. I came to know that convection is one of mandatory part of any model. I am confused how to apply in 2D. In 3D there are edge face, we can easily select faces for convection.
And in material structural steel is enough or need to add material like maxwell ?
February 16, 2022 at 12:57 pmALEXANDRE COSTA
SubscriberHello Akhemka I experienced something similar using the Steady State Thermal and Transient Thermal columns.
My solution was to restart from the scratch and saving as a progressed.
Somehow, it worked.
Best luck Alex
Viewing 7 reply threads- The topic ‘How to fix ”the CAERep is corrupted” in electromagnetic thermal simulation using workbench’ is closed to new replies.
6625
1311
