May 20, 2021 at 11:56 am
Ankanish
SubscriberHi there, I am using Mechanical APDL on a university desktop. When I open the GUI, I cannot see the main menu or command line. I don't know the exact reason but the previous user may have disabled them. My question is, how to get the main menu and default GUI back? I have attached a screenshot for reference. Thanks, Ankanish.
May 21, 2021 at 7:29 amMay 21, 2021 at 11:33 amAnkanish
Thanks for your kind reply. I tried what you suggested, but I am afraid it is not working. I also tried logging into the same system with other account, and checking the GUI. But still I am having the same problem. Is there any other solution.
Thanks, Anish.
May 21, 2021 at 12:34 pmAshish Khemka
Try the following:
Go to Menu Toolbar : PlotCtrls>Windows Controls> Reset Windows Options
Please see if this helps.
Regards Ashish Khemka
May 21, 2021 at 2:20 pmAnkanish
Thanks for your kind reply. Sadly, this solution also does not work.
Regards Anish
May 21, 2021 at 3:52 pmAshish Khemka
This looks like an installation issue. I will move this post to the installation.
May 21, 2021 at 4:03 pmAnkanish
Thanks for your help. Much appreciated!
Regards Anish Kulkarni
November 22, 2022 at 11:14 pmYassine el qamch
SubscriberPlease did you figured out the source of the issue?
Viewing 7 reply threads- The topic ‘Mechanical APDL GUI not showing Main Menu’ is closed to new replies.
6625
1311
