May 20, 2021 at 7:57 am
tpsagaro
SubscriberDear all,
I am simulating a fluidized bed with transient multiphase, eulerian model. In order to have a well defined interfase region between the two phases I applied a refinement criterion in ANSYS-Fluent 2020R1 under the Adapt option:
Adpation Controls => Refinement Criterion => Expression Editor=> Variables => Adaption => AdaptionSpaceGradient(Volumefraction)
May 20, 2021 at 10:12 amRob
Forum ModeratorAdaption controls are in the Domain tab,
and you'll want a cell register to refine and possibly one to coarsen if you're using dynamic adaption. Some of the options changed in the last couple of versions but I think the useful ones are still there. I'd suggest refining on a volume fraction range or gradient and coarsening on the same variable but at a different value(s).
May 20, 2021 at 12:45 pmtpsagaro
SubscriberYes. It works nicely when defining the Gradient of Volume Fraction in a new cell register and choosing it in the Refinement Criterion. There is no need for the AdaptionSpaceGradient variable.
Thanks Rob.
Viewing 2 reply threads- The topic ‘Where are mesh adaption controls in ANSYS-Fluent 2021R1 ?’ is closed to new replies.
6535
1311
