May 16, 2021 at 2:16 pm
Puhan
SubscriberI am unable to give the location of XFEM initiation. How to give it?
May 28, 2021 at 12:23 pm1shan
Ansys EmployeeWhich version are you using ? Are you sure it is compatible with the app? I checked the app documentation and it looks like the scoping method is set to geometry selection in the example that is show in it. You might want to change it and see if it works. Also, what commands are you using? Could you delete that and see if it works.
Regards Ishan.
Viewing 1 reply thread- The topic ‘How to choose ‘crack initiation’ in XFEM Static Propagation Based On Initiation extension?’ is closed to new replies.
6450
