May 13, 2021 at 9:45 am
me18s031
SubscriberI am using ICEM CFD for meshing . In my geometry I want to create a non conformal mesh interface between two fluid zones so that flow passes through that interface. The interface is partially overlapping as shown :
May 13, 2021 at 10:30 amRob
Forum ModeratorFluent automatically sets a wall for the parts of the interface surface that don't match with the other side of the interface. They'll be labelled "wall:123" or the like. The created wall is not displayed separately, and the whole interface surface remains as an interface.
May 13, 2021 at 11:27 amme18s031
SubscriberI wasn't aware of this. Thank you sir for the prompt reply.
May 13, 2021 at 2:14 pmme18s031
SubscriberI ran the simulation with following boundary conditions :
The case has converged to a absolute residual of 10 power (-5). However the velocity contours at the outlet of the channels is not as expected :
Apparently no flow is entering the channels from the semi cylindrical header. However the function calculator in CFD-Post shows mass leaving the outlet and so mass conservation is satisfied:
I am not able to figure this out. Is there any issue in setting up of mesh interface.
Appreciate any help on this.
Thank you.
May 13, 2021 at 3:04 pmRob
Forum ModeratorCheck the fluxes in Fluent and see what that reports.
May 13, 2021 at 8:48 pmme18s031
SubscriberActually I had used only two nodes across the height of the channel . Hence it was reporting zero velocity in the channels. Need to refine the cells. Thank you for your support.
Viewing 5 reply threads- The topic ‘Problems in Creating a non conformal mesh interface in Fluent.’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3882
1414
1241
1118
1015
