How do I continue a simulation in System Coupling GUI after shut down?
    • hnorthrup
      I was running a two-way FSI in the System Coupling GUI and the computer restarted, nothing simulation related. I can't get the simulation to connect again though. When I open System Coupling I choose the same directory as I had when I originally started it and I get the error "Failed to Connect to System Coupling. Press Continue to try again or Quit to exit the application. I try choosing the directory that has the restart file, and System Coupling connects but without any of the participants or set up. Below is the files/folder of the original directory.
    • Steve
      Delete the sycSolve.lock and any .lck or .lock files in the subdirectories and you should be good to go. These files remain since the run wasn't stopped normally.
      Steve
    • hnorthrup
      Thanks so much!
  • The topic ‘How do I continue a simulation in System Coupling GUI after shut down?’ is closed to new replies.
